Hello,
After one unusually hard landing the panel that holds the switches in the dash has broken.
The dash has the typical wood backing and some kind of vinyl like main piece. The switches are set into a seperate plastic panel that is then screwed to the entire dash assembly. The yellow outlined areas in the picture below.
The plastic pieces broke at each corner where it is screwed to the dash.
Any advice on a replacement piece of plastic that is less likely to crack and break?
I don't suppose that someone makes these parts for 20yr old boats?
Thanks.
Thanks.
