What metal is my outbaord made of?
river_bouy
Hi,
I have a 1984 Suzuki DT50. I need to replace the gear case oil drain screw. However, I need to make my own as the official suzuki screw is not long enough to reach the good thread inside the hole. I have a machinist friend who is going to help make the screw but I need to know what metal to make it out of?
Thanks in advance.
TOHATSU GURU
Re: What metal is my outbaord made of?
If you ask a Japanese engineer they will tell you its:
stainress streel
mutch
use 316 stainless steel or 304
304 is cheaper but a little bit of 316 will not be that dear, or you could probably put a recoil thread in and use your old plug ?
Graeme
river_bouy
Thanks for the help. Just what I needed to know.
James R
There seems to be a little confusion here. The motor is made out of aluminum. The screw is SS.
river_bouy
Thanks James R.
I thought the screw would be the same metal as the motor. But easier if it is not as I can just get the right length SS screw and all should be good.
Finding an M10 fine threaded SS screw is a nightmare though. I have to wait 2 months to get it delivered here in Australia.
mutch
james
what thread is 10mm x1.25 pitch i guess it take it to repco and get a recoil thread kit they are easy to put in and use your old plug .
other wise you are going to miss all the summer months
Graeme
