what model is this Starcraft
thebrain
Banned
this is a 1989 SC but what model the side says HL 220V, I believe it's a closed bow Holiday.
I'm concidering obtaining this vessel and would like some details before I take a road trip to inspeact it.
the brochsure for the 1989 is'nt posted here at Iboat
By stevethebrain at 2012-01-09
Thanks STB
starcrafter65
Re: what model is this Starcraft
Buy that!!!
Holiday - I beleive Offshore V Hull
Hard to find - much sought after.
jasoutside
Yah, sure looks like a nice big Holiday to me.
STARCRAFT16SS
what is that on the port side???:confused:...Live well or port a pot with privacy curtain?
Pugetsound
I agree Off Shore 22 ft V5 Hull VERY Clean Looks wellmkept excellent trailer if you like it and price is ok Id buy it a lot of boat with very little no work to enjoy it. Pugetsound. Also nice looking motor
thebrain
Banned
what is the estimated weight of hull I'm assumming around 1500Lbs, engine around 300Lbs & trailer 800Lbs. total load 2600Lbs plus anchors gear ect. tad more weight, am I under estitmating the weight?
I'm also concernded this boat is used exclusively in salt water.
Thanks Guys for feed back
STB
thebrain
Banned
I'm thinking the capsitiy lable on the transome say V5 is this true or false?
also I thought there is a extra long middle chin on the V5 like in the image below.
Thanks STB
jasoutside
Yah, I'd guess you are right in that 2400# range give or take.
GA_Boater
Don't forget fuel. Roughly 7 lbs. per gallon. And add a fudge factor of 5-10% for full coolers, batteries, etc. Why are you so concerned about a few pounds? Are you pulling with a Schwinn?
catfishr1
Yup STB ; That is a nice roomy Holiday with v hull. The hull looks very clean, looks to be in overall good cond. The outboard looks to be in good cond too. I can call starcraft boat co. for you Mon. if you would like to find specs. you r asking for?
catfishr1
Contacted Starcraft Co. today, was refered to dealer in Montacllo. Did get some of info you requested. Boat wt. = 1250#. total payload = 2500#. Boat was designed & built for blue water. They said yes , integrity of bow would be affected by converting to open bow. but was aware it is done all the time? I have not given up on contacting Starcraft direct. Trailer info. dif. matter. Need #s from trailer in order to contact shoreline to recv. pertinent info. on trailer.;) Hope this helps some.
thebrain
Banned
Hello Catfish good infor. on boat, was kindof hopping for a spec sheet that SC could scan and post, surprized they referred you to a dealer guess there more interested in selling a brand new boat.
Just found out this trailer doe'snt have electric brakes it has hydrolic brakes really don't have a clue about connecting brake line from a tow vehical to a trailer setup like this?
Catfish if you do get a chance to talk to SC can you ask the ?s for both the 1989 HL22' and the 1989 MR210
it would be nice to see the omitted SC broscures available.
Thanks STB
ezmobee
That's not how they work. It's all integrated into the trailer. Pressure on the coupler activates the brakes. http://i288.photobucket.com/albums/...ler electric brake conversion/Picture1467.jpg The tow vehicle needs nothing for them to work. Also, while brakes are always nice to have, they aren't really required on that sub-3k lb rig.
thebrain
Banned
I haven't sean the front of the trailers tongue yet, I don't know if this device is mounted to tongue. I know the trailer has a regular 4 pin electrical connecter for tail lights blickers ect.
EZ are you saying that when the tow vehical slows this device inguages the trailers brakes? and there's no other required connections?
years ago a friend of mine had a 1978 Ford PU F150 truck he had a brake controller lever on the left side of his dash told me thats for trailer brakes w/ heavy payload not sure how this controller actualley worked.
Georga requires brakes at 1500 Lbs.
Florida requires brakes at 3000 Lbs
edit1: EZ why doe's this boat have 2 binimi tops one is attached to gunals for roof whats the other smaller top laying on floor for?
edit2: EZ do you think the blue paint on the side can be buffed to look new?
Thanks STB
ezmobee
There are electric brakes, which I believe require a connection to the tow vehicle. The brakes on that trailer are most like what's called "surge brakes". The trailer surging forward as the tow vehicle slows pushes on the couple which acts as the brake pedal. The trailer should have it's only little master cylinder and what not all incorporated.
As for the tops, perhaps you've got a bimini top, and a convertible top. The convertible top attaches to the snaps on the front of the windshield and is made more for weather protection than the bimini.
Bimini (mine):
http://i176.photobucket.com/albums/w200/ezmobee/New Boat/IMG_0460.jpg
Convertible:
http://www.baylinercovers.com/wp-content/uploads/2009/11/Bayliner-175boatTop-300x222.jpg
CheapboatKev
I wouldnt want brakes on something as relatively "light" as that Holiday is.
Just one more item to wear out, rust and fail.
Granted if your tow vechicle is a little wimpy they could be a good thing if maintained.
Pugetsound
Wont find Ellectric brakes on a boat trailer unless its sling launched all the time. Surge master cylynder is on the tounge of the trailer. Regular wireing 4 prong should be whats on the present Connector.
Thanks STB
