so I completed my first diy carb rebuild and fuel pump rebuild. I also installed an in line fuel filter under the cowl. Took the boat out and it starts and I got the idle adjusted, but it won't run past maybe half throttle. It's like it's governed or something. Could this be because of the fuel filter restricting fuel flow? Or is this a sign I did something wrong?
73 Johnson seahorse 6hp. Used all oem parts and I followed the fuel pump rebuild instructions very, very carefully. Felt pretty good about the carb rebuild. I did not soak the carb in a dip and could not get the high speed jet out, but did spray/clean thoroughly 2x.
