OldMercsRule
- Joined
- Nov 30, 2006
- 3,340
Hi guys. I know these are a dumb questions, but most of the advice I have seen regarding the grade of fuel to use in Mercs here on iboats is "mid grade". Trouble is: most of you run newer engines then I do.
I run two 1969 Merc 1000s and when I used to run a 1968 1250 I was told to run premium (93 octain), which I did but may have been expensive overkill.
I also run a 1981 115 and a 1979 115, and three 25 horse Mercs (1989 - 1996). The later engines should be fine with mid grade, (I would think), how about the old girls, (the 1969s 100 hps)?
Second related question: I know ARCO uses 10% alcohol here on the left coast. I use Chevron which does not have the same disclosure on the pump Arco has, (10% alcohol), and does not smell like alcohol like the Arco fuel does. Do all automotive fuels now use alcohol? I would like to avoid if possible. Thanks JR
