FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
If you're talking about engine oil, use Any name brand NMMA FC-W oil for the engine in SAE 30 or 40 wt oil. You can also use a multigrade such as Mercury 25W-40, or as recommended by Mercury
Since OMC no longer exists, The oil suggested by Mercury is the most current info out there.
If you want to change the oil in the vertical drive, use one of the marine (Mercury, Volvo etc) type gear oils or any GL-5 type gear lubricant.
BE ABSOLUTELY SURE THAT YOU DRAIN AND REFILL THE DRIVE IAW THE OMC SERVICE MANUAL. DO NOT FILL IT FROM THE BOTTOM (DRAIN)
I use that same oil in my Cobra 5.0. My shop manual just recommends any SAE 30 oil at temps. above 32deg. If you are crazy enough to be running in temps. below 32deg, it recommends SAE20W-20. The Castrol 30 HD seems to work just fine for me.
