Re: What or is There a Too Long
Assuming that "Deep Creep" is just the spray version of Seafoam, here's how they say to use it...
"With engine warm, keep on high idle and spray through carburetor, or throttle body throat. If engine is port injected, use only vacuum lines that feed all cylinders. When engine is loaded up, turn off ignition. Restart engines after 5 minutes. Make sure exhaust is well ventilated as fumes will be extreme for a short time. Ideal for small engines. Use a Schraeder Valve hose attachment if needed for outboard motors. For further cleaning, use SEA FOAM MOTOR TREATMENT in tank."
And, when you get done with that, you can start on these:
LUBRICATES pulleys, ball bearings, hinges, wheels, fishing reels, sewing machines, valves, locks, rollers, toys, bicycle chains, gears, fan blades and drawers.
