What other years/models can I swap my 1985 25hp Johnson rewind started from?
1roddy
Going to look at a parts motor this afternoon, want to purchase it because i need a recoil and a few smaller parts. It looks a little newwer than mine and am wondering what other years/models i can swap out a rewind started from.. from my research i think a 20-40hp will fit but only 1985-1987? The problem is that my recoil is on the motor at camp so i cant compare the two.. Thanks!
roddy
Beek14
Re: What other years/models can I swap my 1985 25hp Johnson rewind started from?
I've swapped an 84 around with an 88 so that should at least open your options up from 1984-1988. As far as 25 hp models from 1980 and older, you can use recoils from 18, 20, and 25 hp models as far back as the early 60's and they are all interchangeable. The actual parts that grab the flywheel are basically the same in the later 80's models, but the mounts are a bit different.
jerryjerry05
Here you go!!!
EVINRUDE 1981 E25ECIB REWIND STARTER
EVINRUDE 1981 E25ECIM REWIND STARTER
EVINRUDE 1981 E25ELCIB REWIND STARTER
EVINRUDE 1981 E25ELCIM REWIND STARTER
EVINRUDE 1981 E25RCIM REWIND STARTER
EVINRUDE 1981 E25RLCIM REWIND STARTER
EVINRUDE 1981 E25RSA REWIND STARTER
EVINRUDE 1981 E25RSLA REWIND STARTER
EVINRUDE 1981 E25RWCIM REWIND STARTER
EVINRUDE 1981 E25RWLCIM REWIND STARTER
EVINRUDE 1981 E25TECIM REWIND STARTER
EVINRUDE 1981 E25TELCIM REWIND STARTER
EVINRUDE 1981 E35ECIG REWIND STARTER
EVINRUDE 1981 E35ELCG REWIND STARTER
EVINRUDE 1981 E35RCIG REWIND STARTER
EVINRUDE 1981 E35RLCIG REWIND STARTER
EVINRUDE 1982 E25CNE REWIND STARTER
EVINRUDE 1982 E25ELCNE REWIND STARTER
EVINRUDE 1982 E25RCNB REWIND STARTER
EVINRUDE 1982 E25RLCNB REWIND STARTER
EVINRUDE 1982 E25TECNB REWIND STARTER
EVINRUDE 1982 E25TELCNB REWIND STARTER
EVINRUDE 1982 E35ECND REWIND STARTER
EVINRUDE 1982 E35ELCND REWIND STARTER
EVINRUDE 1982 E35RCND REWIND STARTER
EVINRUDE 1982 E35RLCND REWIND STARTER
EVINRUDE 1982 E35TELCNB REWIND STARTER
EVINRUDE 1983 E25ECTD REWIND STARTER
EVINRUDE 1983 E25ELCTD REWIND STARTER
EVINRUDE 1983 E25RCTE REWIND STARTER
EVINRUDE 1983 E25RLCTE REWIND STARTER
EVINRUDE 1983 E25RSLS REWIND STARTER
EVINRUDE 1983 E25RSS REWIND STARTER
EVINRUDE 1983 E25RWCTE REWIND STARTER
EVINRUDE 1983 E25RWLCTE REWIND STARTER
EVINRUDE 1983 E25TECTE REWIND STARTER
EVINRUDE 1983 E25TELCTE REWIND STARTER
EVINRUDE 1983 E35ECTS REWIND STARTER
EVINRUDE 1983 E35ELCTS REWIND STARTER
EVINRUDE 1983 E35RCTS REWIND STARTER
EVINRUDE 1983 E35RLCTS REWIND STARTER
EVINRUDE 1983 E35TELCTS REWIND STARTER
EVINRUDE 1984 E25ECRS REWIND STARTER
EVINRUDE 1984 E25ELCRS REWIND STARTER
EVINRUDE 1984 E25RCRD REWIND STARTER
EVINRUDE 1984 E25RLCRD REWIND STARTER
EVINRUDE 1984 E25RWCRD REWIND STARTER
EVINRUDE 1984 E25RWLCRD REWIND STARTER
EVINRUDE 1984 E25TECRD REWIND STARTER
EVINRUDE 1984 E25TELCRD REWIND STARTER
EVINRUDE 1984 E30ECRR REWIND STARTER
EVINRUDE 1984 E30ELCRR REWIND STARTER
EVINRUDE 1984 E35ECRR REWIND STARTER
EVINRUDE 1984 E35ELCRR REWIND STARTER
EVINRUDE 1984 E35RCRR REWIND STARTER
EVINRUDE 1984 E35RLCRR REWIND STARTER
EVINRUDE 1984 E35TELCRR REWIND STARTER
EVINRUDE 1985 E20CRCOS REWIND STARTER
EVINRUDE 1985 E20CRLCOS REWIND STARTER
EVINRUDE 1985 E20ECOS REWIND STARTER
EVINRUDE 1985 E20ELCOS REWIND STARTER
EVINRUDE 1985 E25ECOC REWIND STARTER
EVINRUDE 1985 E25ELCOC REWIND STARTER
EVINRUDE 1985 E25RCOS REWIND STARTER
EVINRUDE 1985 E25RLCOS REWIND STARTER
EVINRUDE 1985 E25RWCOS REWIND STARTER
EVINRUDE 1985 E25RWLCOS REWIND STARTER
EVINRUDE 1985 E25TECOS REWIND STARTER
EVINRUDE 1985 E25TELCOS REWIND STARTER
EVINRUDE 1985 E30ECOA REWIND STARTER
EVINRUDE 1985 E30ELCOA REWIND STARTER
EVINRUDE 1985 E30RCOA REWIND STARTER
EVINRUDE 1985 E30RLCOA REWIND STARTER
EVINRUDE 1985 E30TECOA REWIND STARTER
EVINRUDE 1985 E30TELCOA REWIND STARTER
EVINRUDE 1986 E25RWCDC REWIND STARTER
EVINRUDE 1986 E25RWLCDC REWIND STARTER
EVINRUDE 1987 E20CRCUR REWIND STARTER
EVINRUDE 1987 E20CRLCUR REWIND STARTER
EVINRUDE 1987 E20ECUR REWIND STARTER
EVINRUDE 1987 E20ELCUR REWIND STARTER
EVINRUDE 1987 E25ECUA REWIND STARTER
EVINRUDE 1987 E25ELCUA REWIND STARTER
EVINRUDE 1987 E25RCUR REWIND STARTER
EVINRUDE 1987 E25RLCUR REWIND STARTER
EVINRUDE 1987 E25RWCUR REWIND STARTER
EVINRUDE 1987 E25RWLCUR REWIND STARTER
EVINRUDE 1987 E25TECUR REWIND STARTER
EVINRUDE 1987 E25TELCUR REWIND STARTER
EVINRUDE 1987 E30ECUB REWIND STARTER
EVINRUDE 1987 E30ELCUB REWIND STARTER
EVINRUDE 1987 E30RCUB REWIND STARTER
EVINRUDE 1987 E30RLCUB REWIND STARTER
EVINRUDE 1987 E30TECUB REWIND STARTER
EVINRUDE 1987 E30TELCUB REWIND STARTER
EVINRUDE 1987 E35RCUB REWIND STARTER
EVINRUDE 1987 E35RLCUB REWIND STARTER
JOHNSON 1981 J25ECIB REWIND STARTER
JOHNSON 1981 J25ECIM REWIND STARTER
JOHNSON 1981 J25ELCIB REWIND STARTER
JOHNSON 1981 J25ELCIM REWIND STARTER
JOHNSON 1981 J25RCIM REWIND STARTER
JOHNSON 1981 J25RLCIM REWIND STARTER
JOHNSON 1981 J25RSA REWIND STARTER
JOHNSON 1981 J25RSLA REWIND STARTER
JOHNSON 1981 J25RWCIM REWIND STARTER
JOHNSON 1981 J25RWLCIM REWIND STARTER
JOHNSON 1981 J25TECIM REWIND STARTER
JOHNSON 1981 J25TELCIM REWIND STARTER
JOHNSON 1981 J35ECIG REWIND STARTER
JOHNSON 1981 J35ELCIG REWIND STARTER
JOHNSON 1981 J35RCIG REWIND STARTER
JOHNSON 1981 J35RLCIG REWIND STARTER
JOHNSON 1982 J25ECNE REWIND STARTER
JOHNSON 1982 J25ELCNE REWIND STARTER
JOHNSON 1982 J25RCNB REWIND STARTER
JOHNSON 1982 J25RELCNB REWIND STARTER
JOHNSON 1982 J25RLCNB REWIND STARTER
JOHNSON 1982 J25TECNB REWIND STARTER
JOHNSON 1982 J35ECND REWIND STARTER
JOHNSON 1982 J35ELCND REWIND STARTER
JOHNSON 1982 J35RCND REWIND STARTER
JOHNSON 1982 J35RLCND REWIND STARTER
JOHNSON 1982 J35TELCNB REWIND STARTER
JOHNSON 1983 J25ECTD REWIND STARTER
JOHNSON 1983 J25ELCTD REWIND STARTER
JOHNSON 1983 J25RCTE REWIND STARTER
JOHNSON 1983 J25RLCTE REWIND STARTER
JOHNSON 1983 J25RSLS REWIND STARTER
JOHNSON 1983 J25RSS REWIND STARTER
JOHNSON 1983 J25RWCTE REWIND STARTER
JOHNSON 1983 J25RWLCTE REWIND STARTER
JOHNSON 1983 J25TECTE REWIND STARTER
JOHNSON 1983 J25TELCTE REWIND STARTER
JOHNSON 1983 J35ECTS REWIND STARTER
JOHNSON 1983 J35ELCTS REWIND STARTER
JOHNSON 1983 J35RCTS REWIND STARTER
JOHNSON 1983 J35RLCTS REWIND STARTER
JOHNSON 1983 J35TELCTS REWIND STARTER
JOHNSON 1984 J25ECRS REWIND STARTER
JOHNSON 1984 J25ELCRS REWIND STARTER
JOHNSON 1984 J25RCRD REWIND STARTER
JOHNSON 1984 J25RLCRD REWIND STARTER
JOHNSON 1984 J25RWCRD REWIND STARTER
JOHNSON 1984 J25RWLCRD REWIND STARTER
JOHNSON 1984 J25TECRD REWIND STARTER
JOHNSON 1984 J25TELCRD REWIND STARTER
JOHNSON 1984 J30ECRR REWIND STARTER
JOHNSON 1984 J30ELCRR REWIND STARTER
JOHNSON 1984 J35ECRR REWIND STARTER
JOHNSON 1984 J35ELCRR REWIND STARTER
JOHNSON 1984 J35RCRR REWIND STARTER
JOHNSON 1984 J35RLCRR REWIND STARTER
JOHNSON 1984 J35TELCRR REWIND STARTER
JOHNSON 1985 J20CRCOS REWIND STARTER
JOHNSON 1985 J20CRLCOS REWIND STARTER
JOHNSON 1985 J20ECOS REWIND STARTER
JOHNSON 1985 J20ELCOS REWIND STARTER
JOHNSON 1985 J25ECOC REWIND STARTER
JOHNSON 1985 J25ELCOC REWIND STARTER
JOHNSON 1985 J25RCOS REWIND STARTER
JOHNSON 1985 J25RLCOS REWIND STARTER
JOHNSON 1985 J25RWCOS REWIND STARTER
JOHNSON 1985 J25RWLCOS REWIND STARTER
JOHNSON 1985 J25TECOS REWIND STARTER
JOHNSON 1985 J25TELCOS REWIND STARTER
JOHNSON 1985 J30ECOA REWIND STARTER
JOHNSON 1985 J30ELCOA REWIND STARTER
JOHNSON 1985 J30RCOA REWIND STARTER
JOHNSON 1985 J30RLCOA REWIND STARTER
JOHNSON 1985 J30TECOA REWIND STARTER
JOHNSON 1985 J30TELCOA REWIND STARTER
JOHNSON 1986 J25RWCDC REWIND STARTER
JOHNSON 1986 J25RWLCDC REWIND STARTER
JOHNSON 1987 J20CRCUR REWIND STARTER
JOHNSON 1987 J20CRLCUR REWIND STARTER
JOHNSON 1987 J20ECUR REWIND STARTER
JOHNSON 1987 J20ELCUR REWIND STARTER
JOHNSON 1987 J25ECUA REWIND STARTER
JOHNSON 1987 J25ELCUA REWIND STARTER
JOHNSON 1987 J25RCUR REWIND STARTER
JOHNSON 1987 J25RLCUR REWIND STARTER
JOHNSON 1987 J25RWCUR REWIND STARTER
JOHNSON 1987 J25RWLCUR REWIND STARTER
JOHNSON 1987 J25TECUR REWIND STARTER
JOHNSON 1987 J25TELCUR REWIND STARTER
JOHNSON 1987 J30ECUB REWIND STARTER
JOHNSON 1987 J30ELCUB REWIND STARTER
JOHNSON 1987 J30RCUB REWIND STARTER
JOHNSON 1987 J30RLCUB REWIND STARTER
JOHNSON 1987 J30TECUB REWIND STARTER
JOHNSON 1987 J30TELCUB REWIND STARTER
JOHNSON 1987 J35RCUB REWIND STARTER
JOHNSON 1987 J35RLCUB REWIND STARTER
