What plugs do I use now?
MR nova @#25
I have a pair of newly Rebuilt Ford 302 motors, with 4bbl carbs and pertronix distributors. Whats plugs and gap should I use
Thanks
MR nova @#25
The new heads on the block are 351. The plugs listed in one of the Mercruiser sites, list Part# 33813425.this plug is to small diameter.
achris
More fish than mountain goat
There are 2 common plug thread sizes. 18mm, which normally have a compression gasket as part of the plug (see below picture #1), and the head has a 'square' seat. And 14mm which is a tapered seat plug (picture #2). When Mercruiser were using the Ford engines, they were also both heads around, often at the same time. :facepalm:
If the head has 14mm tapered seat holes, the right plug should be AC-MR43T (NGK BR6FS). If the head has square seat 18mm holes, then it should be AC-CR83T (NGK AR6FS)...
The gap should be 0.76mm for either plug.
Chris..........
Picture #1 (18mm plugs with compression gasket)
Click image for larger version  Name:	18mm plug.JPG Views:	1 Size:	60.5 KB ID:	10902089
Picture #2 (14mm plug with tapered seat)
Click image for larger version  Name:	14mm plug.JPG Views:	1 Size:	13.0 KB ID:	10902090
