what pole on tach?
spacerust
i have 73 135hp johnson that i am installing a tach on. what pole should i put it on?
bob johnson
Re: what pole on tach?
how about a 1997 90 hp Evinrude 60 degree looper?
thanks
bob
Nandy
thanks
bob
Bob, you are probably best starting your own thread in the evinrude forum. I know all 2 cycle "rudes" with 70 hp or larger are set to 6p. So I will guess your is not set to 6p. You can always set the tach to every setting and then see which is close to what your idle rpm is supposed to be... not the best approach but possible.
Good luck!
bob johnson
Good luck!
well I posted I do have a "rude" larger than 70 hp!!!!
I understand when you have a really different question you should open a new thread...but this is almost the exact same question!!! all those with the answer for the op's question probably know the answer to mine
thanks
bob
