What prop is this really
belairbrian
Part number on prop is 48-73132-10.
One site shows: 15 DEGREE PROGRESSIVE PITCH -- Used on Mercury outboards, 35 HP through 140 HP. Usually have a 3 inch progressive pitch. Stainless steel and aluminum propellers. Doesn't mention diameter.
Is currently on a 1999 40HP Force (pushing 20 ft pontoon). Might be slipping and if so need to replace.
steelespike
Re: What prop is this really
Pitch is expressed in inches. Usually the number at the end is the pitch 10 Might be for a pontoon.
Usually slip is the difference between theoretical speed and actual speed. Expressed in a %.ie.10 % slip.
The prop losing grip is ventilation The prop becomes air fouled.
If the prop is defective with a bad hub its called a spun hub. Ventilation and a spun hub seem the same
but ventilation may happen at at different speeds or triggered by waves,while a spun hub usually happens at roughly the same power range.You can check the hub by putting a water proof line across the hub and doing a test run.Line will be broken if hub is bad..
If a smallish prop probably a new prop is more cost affective.
Pretty sure the 99 Force uses a Merc prop and has a Merc leg.
