What prop is this ?
philip24
I found a prop but I don't know what it is. I can barley read the numbers I think it says 501 265 1 then on the side it says 14X13 thanks for the help
raysprops
Re: What prop is this ?
Can you give a little more info. How many blades, thru hub or non thru hub exhaust, Pin drive, etc. will all help. Do you have any idea wwhat make it might fit?
All I can tell you is that it is a 14-degree pitch and a 13-inch diameter. More information would help tremendously
