What prop should I have
frekels21
i have a 1976 century raven 190 with a chevy 4.1L 250 in it and i was trying to figure out what would be the correct prop to put on it. i dont know the max RPM because i can not find it anywhere does anyone know where i can find it?
steelespike
Re: What prop should I have
Is there a prop on it now?Do you know the present max rpm and speed.
frekels21
yea there is a 19 inch pitc one on there now and it will run about 32 mph at 3800 rpm
steelespike
I was not able to find your rated rpm but would guess 3800 to 4200.
It does seem a little slow seems like 35 to 40 would be possible.
Is the speed by gps?What is the weight? is it a deep V? rounded bottom?etc.
what is the deadrise?Is the motor in excellent tune? throttle opening all the way.
(Throttle plates open)Prop excellent?Compression?Do you know the gear ratio?
frekels21
yea the speed was by GPS. the boat weighs 2500 lbs as my best guess, its a deep V. the motor was rebuilt last year so it is tuned to perfection. the prop is in good condition and the ear ratio is 1.32 to 1 i believe.
