what prop to start with??? what are you guys using for 85 liberator with newer 350m/c
iiazzii
Hey guys,
I am restoring an 85 four winns liberator and i am getting to the point of getting motor in, so i need help on what prop i am going to need or atleast a decent starting point.
specs
1985 21' liberator
listed at 2800 lbs.
350 5.7L mercruiser 250HP
thru hull exhaust
alpha 1 gen 2 outdrive
...not sure what other info is needed
thanks and i appreciate any help for this newbie!
-dan
Robbabob
Re: what prop to start with??? what are you guys using for 85 liberator with newer 35
What info is needed.... usually we use this link to start people off: http://forums.iboats.com/showthread.php?t=287818
Your case is a little different...
What's the gear ratio on the outdrive?
Are you wanting to use SS or AL?
Do you have soft or hard contact?
You want all-around performance or primary to tubing and skiing?
Do you have access to test props before purchase?
Good luck :cool:
