What prop
armymike63b
I have an 87 Glastron Conroy Z-16 with an 88hp evinrude does anyone know what the stock prop size is and what's the diff between 3 and 4 blade ?
180shabah
Re: What prop
Props are a dealer installed item, there is no "stock" size.
What is on it now, and what are your WOT numbers.
Re: What prop
4 blades are completely unnecessary (more drag) unless you're running a surfacing prop on a raceboat. You can go to Dan's discount Props, e.g., and look at the range of pitches offered for your motor. I don't know the gear ratio of your motor, but would expect that with a 1970s-1980s 135 or 140 and your heavy boat you'd likely need about 19"-21" pitch. The 135s and 140s were geared 2:1.
QC
Re: What prop
Funny you mention Hill in another post as a good prop source, he even makes a six blade . . . You should call Ron and tell him that his four blades are "unnecessary". I am currently running one of his and it is comparable to the Merc Bravo 1 four blade that is obviously even more common. You need to brush up on the current state of recreational props ;)
Re: What prop
All sorts of things have been tried, not all work, and not all are improvements. I'm not up on commercial offerings. My main interest is in surfacing props. I can imagine that 4 blades may be smoother than 3, I can also guess that 4 blades submerged drag more than 3. Six blades?!
180shabah
Re: What prop
I'm not up on commercial offerings...
Then why say "4 blades are completely unnecessary" if you don't know.
That extra blade makes a big difference in hole shot, typicaly has better midrange acceleration and holds plane at slightly lower speed. Low speed handling is vastly improved, especially in reverse.
Is there an efficiency hit, sure. Most boats will loose 1-2mph off the top end, but your average recreational boater spends alot more time cruising and pulling tubes, skiers etc than they do running WOT.
QC
Re: What prop
But that's what most of our members are concerned with . . . ;)
Take a look at the Sticky ^^^^ with Walleyeheds test results. A little (lot) hard to read, but there is some very good data there.
Re: What prop
Yep, and I'm here for the 1% who want something more than tubing, etc!
