What Prop"?
chrisnlbc
Hey Guys,
My 1989 Force 125 needs a new prop. I have a 1988 as a spare parts motors, but the props and nuts are totally different. Is this the right prop I would need?http://boatpropellers.iboats.com/Force/125_HP_(1988-1989)_17.00-Pitch_Michigan_Match_Aluminum_071036_Propeller/177/372/?*******=277655043
I assume I have dual exhaust because my exhaust comes thru the hub and the two holes in the mid unit. Thanks for the assistance! Also the boat is a Capri 1902, im thinking of running a 17p?
Chris
jerryjerry05
Re: What Prop"?
That will fit.
Most of your exhaust comes through the snout on the bottom of the cavitation plate.
The 2 holes are for excess water pressure.
Post a pic of the old prop.Sounds like you have an early Chrysler/Force prop.
As far as running a 17p what was on there??
To figure out the right prop you need to figure out what RPM's at WOT is???
That motor should hit about 5300-5500 at WOT.
Send your old out to be fixed and keep it as a spare.Cheaper too!
chrisnlbc
Re: What Prop"?
Thanks Jerry I will snap a pic of the one thats on there right now and post. Appreciate all the info.
Chris
