What shaft length do I need for a kicker motor?
michaeloberg
Here is a tape measure hanging off the top of my transom. The motor won't sit very low on the perch because it is so shallow of a transom.5.jpg
Taking tips on hanging the bugger also, I don't want a jack plate.
Sea Rider
Needs to be at least an L shaft but probably an XL will work much better powering said boat while sitting port of main..
Happy Boating
roscoe
I would suggest a long shaft. Should be good to get the prop below the hull.
Any longer and you won't be able to tilt the gearcase out of the water, and you will be dragging it around in the water when using the main motor.
