What should compression be on this motor?
Hoyt79
1976 55 HP Johnson and also what should be the tolerance between cylinders?
DargelJohn
Re: What should compression be on this motor?
First concern is the compression tolerance between the cylinders. All compression readings should be within 10% of each other.
Compression readings should be above 100#, range (120-150#).
Hoyt79
Thanks! Next question...I have access to lots of 100LL aviation gasoline. It's 100 octane with a little lead in it, wondering if this would be acceptable to run in the motor, rather than fuel with ethanol in it.
DargelJohn
I would say no. Outboards are designed to run on 87 Octane fuel.
Hoyt79
Ok. How do we fix the problem with the ethanol in the fuel, these motors were not designed for ethanol.
jtexas
agree, it's probably a bad idea to run avgas in your motor. no doubt it will run, but I have a feeling it wouldn't perform as well and probably has some long-term consequences.
The original rubber fuel system components in your 1976 outboard might be alcohol-resistent, but probably not. If the carbs & fuel pump have been rebuilt since the mid-80's, and fuel lines replaced, then the motor will run just fine on E-10. I've been running it in a '79 model for years with no problems.
The main problem with E-10 (apart from adding to the cost of gasoline while making it less powerful), is in the handling & storage. If water gets in the tank, it's more likely to be more trouble than straight gasoline. Any water dissolved in the gas will take the ethanol with it if/when it separates (which will happen if the temperature drops); then the whole batch is worthless.
The PRIG treatment mentioned above looks like pretty good stuff, but it claims to restore bad gas to usable condition, I'm pretty skeptical about that. I'd be interested to learn whether you've experienced that. I add seafoam to my gas, so the carbs stay clean & the cylinders don't get coked up, but it won't do anything about the ethanol.
Joe Reeves
In agreement with John pertaining to the high compression on that engine, also with the 10% difference between cylinders..... however 15 psi difference would give me concern for worry.
The mentioned PRI-G..... I think I'll look into that as I have two vehicles (in very good condition), a 1988 Ford F150 and a 1989 Ford Crown Victoria (both 302 engs) that are now running lousy due to this "ethanol" BS (my opinion). Is it available in stores or just online?
Hoyt79
Just bought the boat and got it home about an hour ago...compression readings were 135 psi on top cylinder and 130 psi on bottom!
