OutboardNewbie313
Thread starter- Joined
- Apr 17, 2008
- 22
I'm new to the whole outboard motor thing. I'm hoping someone can give me some insight into the problems I should look for with this motor I bought.
I just picked up an old 1975ish 5.5hp Ted Williams Sears Eska 217.59980 for $80 bucks. It starts on the second pull almost everytime and runs pretty good although I've only ran it in a bucket for no longer then 10 minutes. I already opened the lower gear part and noticed it had almost no oil in the gear case so I ordered the gasket (the very bottom one for the lower gear case) from Sears. I'm hoping after I install the gasket and refill the oil that this problem is solved. The gaskets for the oil hole screws still look good so I don't believe the oil is leaking out from there. I am getting water through the shaft and out the top holes so I'm assuming the pump is still good. Beside these issues, what other things should I look for to fix before I give this thing a good test run on the water? I'd hate for it to blow up on me first time out.
What is the correct oil to fuel ratio? Do I use marine oil or chainsaw/lawnmower oil (I've heard both ways)?
All help and information is greatly appreciated. Thanks for your time and help in advance.
