What should it cost to replace cracked block?
thompmik
How much should it cost me to have my engine replaced? The block is cracked but the manifolds are fine. Its a 1992 mercruiser 4.3 LX <br />I just spent $1800 on the outdrive and a new manifold just to find out the block also had a crack. The boat is only worth about $7500 in good condition. Not sure what to do.
meat76head
Re: What should it cost to replace cracked block?
I'm in the process of replacing a 5.0 with a 5.7 long block. It's running around $4k for parts and labor with my mechanic doing the work.
waterdog85170
depends on where ya go. most shops down here in pueblo are around 100.00 an hour for the labor plus a new motor. i work on boats in my garage and i think the last 4.3 i did was around 3000.00. by the way, where in colo are you?
waterdog85170
i can put together a few different options for you if you would like. if interested give me a call. 719-778-2866-jeff
thompmik
I'm in Parker. A big dealer up here in south Denver said it would be $4500 to $6000. Seemed kinda high to me.<br /><br />If I'm putting in a new motor would it be the same price to upgrade the power? Maybe to a 5.0 or something.
