I HAVE TWO 150HP JOHNSON OCEAN RUNNERS MODEL HJ150NXEOM SERIAL NO GO3793333 I HAVE A 4 BLADE 15 INCH PROPS ON . AT WIDE OPEN THROTTLE WHAT SHOULD MY REVS BE?
your revs should be around 5500 to 6000 RPM. If you aren't around this RPM, then you may need to try a different set of props, or look at the way the motors are setup on the boat.<br /><br />P.S. turn off your Caps Lock, it's considered shouting to write a whole message in capital letters
