What should the Idle RPM Be
cat toon
I think my idle speed is to low on mt 1987 70 horse Johnson motor what should the idle speed be.
boobie
Re: What should the Idle RPM Be
725 +- 25 RPM in gear with the boat in the water.
cat toon
I do not understand,when you put the motor in gear the you give it gas also then it is not at an Idle,I always thought at and idle is with no gas except what the carp normally add without the trottle engagued.
bob johnson
well you didnt say what kind of controls you have...( could be a tiller even!!)
but on a single lever control once the throttle is moved to just fully engage forward...thats idle in gear!
and you need the back pressure of the motor in the water.
engaging the gears naturally add resistance.... but this is what idle in gear is....with the "drain" of the drive shaft turning a prop....
thats how i thought it was
bob
boobie
Cat, listen to what Bob said.................
cat toon
ok,I got it now,My 70 horse is about 950 without being in gear is that to low may stall out when put in gear,I just put that motor on my pontoon and have NOT test driven it yet.
Thank you very much for setting me straight.
bob johnson
make sure the motor is warmed up prior to setting idle, it might just fall perfect where you want it!!!(750 rpm)
bob
