What Size Bolt for Engine Stand
JohnHappy
Will soon be pulling my MMC 7.4L, 454 big block (Gen V, 1994). I want to be prepared to put it on my engine stand. My Mercruiser engine documentation does not tell me what size bolt I'll need to connect my stand to the engine. Does anyone out there know what diameter bolt I'll need to have on hand?
zbnutcase
Re: What Size Bolt for Engine Stand
3/8-16, grade 8, length depends on the stand, but you will want about an inch going into the block.
6meter
The biggest size that will fit through the back of the block. Small blocks are bolted to trannys with 3/8". I'm thinking big blocks bolt to the same trannys, so 3/8" Isn't the block tapped?
Ayuh,.... Zb is Right,... 3/8"- 16x an inch longer than the ears of the stand...
Alpheus
Don't forget to use grade 8 washers as well. There is a pick on the net somewhere where the head of the bolt pulled clear through an el-cheapo washer and his engine (big block chevy) wound up on the floor...
JohnHappy
OK, looks like the consensus is grade 8, 3/8" bolts that are one inch longer than the ears on my engine stand as well as grade 8 washers.
Thanks!:)
