Robertpel9
Thread starter- Joined
- Apr 20, 2008
- 265
Need to remove the bearing cover on my SX as the previous owner overtightned it and stripped the threads where the dipstick goes in
If i looked at this right i need to remove three bolts and the rear cover with the SX label will come off and then i will have access to all 4 bolts holding the bearing cover on, is this correct?? If so what size socket removes all of these?
Also I have a top notch machinist at my factory who can put a helicoil in no problem, since i am reusing the same cap do i need to worry about shimming it or can i just make sure the original shimming is on there? What size helicoil will need to be installed
This looks like a fairly common issue, I'd like to fix it for free myself but just want to make sure i have the tools and the know how to do it
Thanks,
Robert
Thanks,
Robert
