What size? how many HP?
hoverman
i have a 1991 monterey and want to purchase an oil change hose kit but i do not know what the drain pan plug size is? i was told that the block is a gm truck 5.7 engine?any help? also how many hp does my engine have?
here are the serial numbers
engine # 0d612561
transom # 0d571764 (what the heck is a transom number??)
driver serial # 0d563751
5.7l engine 350 cid
ignition timing 8 degrees btdc
cyl firing order 1-8-4-3-6-5-7-2
spark plug gap .035
spark plug ac mr43t
max wto 4200 rpm
Don S
Re: What size? how many HP?
It's a 5.7 GM engine, but it's a Marine engine not a Truck engine. Blocks are the same, it's what's in them that makes them marine or truck.
You also have an Alpha I Gen II outdrive
Gimbal housing assembly, inside and out. Includes trim pump.
Head up to the Adults Only sticky at the top of the forum. You can download the OEM service manual with all the specs in it.
You want manual #15 for the engine, 14 for the drive.
