What size is allen head bolt on exhaust snout
gwgautney
I have a 1986 85hp force. I had to cut allen head bolt that holds it on. Could anyone tell me what size that bolt is. I was wanting to pick one up on my way home from work. Thanks
Frank Acampora
Re: What size is allen head bolt on exhaust snout
I believe it is 5/16 - 18 X 1 inch long. Curious: With the tight clearance inside the snout, how did you manage to cut it off?
jerryjerry05
I used a VERY sharp drill bit to cut the head down.
When you buy new.
Make sure it's stainless.
gwgautney
Snout had to replaced when I got finished.
Redfred1
Saw the thread; got me wondering. I dropped the lower unit on my '89 85 with just the six bolts. The snout came off in place. Got me wondering if that bolt should be longer. Will look when it goes back on. (JJ; haven't updated; is TDC here and colder is on the way. Also; had PTO clutch problems on the big tractor). RF
jerryjerry05
Redfred.
There is 2 bolts/screws holding the snout in place.
There should be another 5/16-18X1 bolt under the snout.
