What size of engine for 3.1m
bbjunkie
Hi
I have a Wetline/Waterline AR310 inflatable with inflatable keel/floor.
Transom plate says max motor weight 50kg max power 10hp
Currently I am using a 4hp which isn't strong enough to get it past 5mph at WOT. (lifts the nose real high when im in it on my own, doesn't seem to have enough power to lift the stern out of the hole)
Would there be much difference between a 8hp and 10hp in speed? Also, would there be much difference if I was to go to 4 stroke? (I know 2 strokes are lighter)
Usually there would just be two of us and some fishing stuff in the boat, approx max 400lb of people and stuff.
Great forums here btw
Cheers
Pete
Howard Sterndrive
Re: What size of engine for 3.1m
I would put a 9.9 on it. Inflatables work best when powered to their max.
2 or 4 stroke just a personal choice, and probably better discussed in this forum:
http://forums.iboats.com/forumdisplay.php?f=16
but ask about various angles you can store the 4 stroke. Some need to be laid down a certain way and for a tender or boat that is deflated frequently or mini-van'd to the lake, this can be a factor.
Local reg's on 2 stroke use also a factor.
bbjunkie
Decided to go for a Honda BF10 - Great engine!
Now if I can get the prop to actually grip the water i'll be all set - It's loosing grip when engine reaches 3500-4000 rpm (9-1/4x9)
Pete
flwestcoastboater
I had that same problem with a 5hp on a choppy day in my inflatable. Never solved the problem, got a new motor for a sailboat too :)
The honda 4 strokes work very well! I have had a bf5 for a while now, besides a gas fitting issue, it has been trouble free for me. The 10hp must plane the inflatable very nicely!
