Cannondale
- Joined
- May 22, 2010
- 278
Re: what size trailer hitch should I have!
I'm sure you mean, when you say subtract that weight, you mean the tongue weight. The trailer/towed weight is relevant only for the GCWR, not the GVWR....which is what you subtract the tongue weight from to determine what sort of loading you can put into the vehicle. That is, unless you mount your trailer/boat on top of your vehicle and then you are correct in subtracting the total towed weight from the GVWR.
A PT cruiser is rated for 1000lbs and 100lbs tongue weight. Subtract from that rating the load in the vehicle (driver, passengers, cargo, etc). Not even counting any of that you're already over twice the rated capacity of your car. To put it in perspective I pull a roughly 3000lb trailer with electric brakes with a 5000lb rated mid size SUV and would not want to pull any more than 3500lbs at highway speeds. I made it my own personal rule not to pull more than two thirds of rated capacity if the vehicle's smaller than a full size pickup.
