Re: What Starter Is Better
i basically have 2 problems with my starter the first is while cranking the engine the shaft disengages (drops down) from the fly wheel and just spins, it will only usually crank the fly while for like 5 seconds before it drops down. I lubed the shaft but hasn't helped. The second problem is when turning the key the starter will make clicking noises and the drive gear barely turns, if I release the key and go spin the gear a few times it then usually will work.
