Kicker9158
Thread starter- Joined
- Aug 19, 2010
- 21
I posted (Thermostat or no thermostat?) and was informed that a thermostat is needed. Although during my searches through the threads I saw somebody posted, you want diferrent temperature thermostats for salt water and fresh. I'm almost sure what I read was you want a cooler thermostat in salt water because hotter water crystalizes the salt? I can not find that post anymore, can someone confirm if this is correct? I will be using this motor in both salt and fresh water. Also what part number of the two below is the cooler thermostat if possible. According to the site I checked it recommended these part numbers, but I could not find the temps.
Thank you
My engine is a honda #B100-1001804
Part #19300-881-741 (or) Part #19300-921-003
Thank you
