what throttle cable for my 1977 evinrude 140
troysidwell
i need help..i just pulled my old motor off wich was a 1986 johnson 110,and installed a 1977 evinrude 140.now the problem im having is the throttle cable does not work on the evinrude.it will not stay on the little nipple,and their is nothing to hold it in place.ive been looking but cant seem to find the right cable,please someone show me wich one and where to get the right cable,my modle # is 140743s
interalian
No Title
The '77 motor uses the older clip-on cables. The motor ends look like this:
Text snipped from the BRP parts list. USE THROTTLE AND SHIFT CABLES (377365 5 FT) THRU (379850 50 FT).
interalian
Oh, and have you done a compression test on your new motor? Water pump? ...?
troysidwell
compression is 130,125,125,125,i ordered the water pump kit..
so I found the cable end,now the cable to use is type 400??
oldboat1
curious. Don't the '86 and '77 throttle cables interchange? Think the cable clamps at the covers are the same. Maybe you are missing that end clamp (#21 in Interalian's post) -- same on both the old cables and the quick release versions, I think. Older cables use set screws on the ends.
Chinewalker
I concur - you match the cables to the controls, not the motor. Making an assumption here that the controls for your 1986 were of 1986 vintage as well. If that's the case, your 1977 should just take the same cables. I believe for the 1977, you need to add cable clip 0310729 to hook your existing cable up properly.
interalian
How about a pic of where the cables fit on your '77? A picture is worth a thousand words, or so they say.
