just bought a starcraft ss160 for my 2011 60hp etec.now I will have a cedarstrip boat of 17 feet length with no motor to sell.boat is beautiful and I think would sell for much more with a motor attached.i have looked over the 85 and it will need a lower unit seal replacement,and the tilt trim will need to be o ringed also.now on to the meat of the problems.motor was running and just stopped and has no spark atall.previous owner had it tested and stator is no good apparently.i tried another power pac and it was still dead so im leaning to believing the stator is pooched.outboard ignition.com has several easy tests im going to do tomorrow to make sure im on the right track.ive done a comp test already and I got an amazing 120psi on all cylinders with a good comp tester.you could eat off of this motor it is so clean and the paint on said powerhead is like brand new.is this motor worth putting 400 or so into it?the Johnson is a 1976 model with the 6 amp stator .I think i could recoup my investment on the motor with the added value of the cedarstrip sold with a good running motor.any thoughts on this ?any other tests I might do to make sure its the stator ?
