freeisforme
Thread starter- Joined
- Mar 23, 2009
- 184
I picked up a nice clean older Mercury 200 today, it's a good match for my 14' aluminum boat.
The motor runs like a top, has seen only freshwater use, has a reman power head last season, done a local dealer, new water pump kit and a resealed lower unit. All still under warranty. I test ran the motor on the sellers boat, it outrigh flew on a 16' flat bottom boat but I had no real means of figuring top speed and really didn't feel I got it anywhere near its top speed with that motor.
My question is, what should I expect from a healthy Mercury 20 HP 2 stroke on a 400 lb 14 1/2' flat bottom V hull with two guys and gear in it totally around 600lbs. (Boat has a 1150lb max and a 25 hp max). I was going to buy a newer motor but this came about, and at a price I couldn't refuse.
I have the chance to sell it for a decent profit but if it will do the job on my boat, I don't see the sense in selling it since I own it really right.
$120 sure beats $3200 or for a new motor which I was looking at, and the older motor is a good bit lighter than the new 4 stroke.
I would be more than happy if this tops out in the 25 to 30 range, I had a similar boat with a 15 hp that ran out at about 23, so this should be a bit stronger than that boat, plus this boat is a lot lighter than my old boat, by at least 300lbs or more.
Of course this is assuming that this motor is propped to match the boat for recommended RPM.
Anyone have any examples out there running one of these older Mercs on an aluminum boat?
