Sparkyman215
Thread starter- Joined
- Jul 26, 2010
- 1
So I cracked the block of my 98 4.3 Carbureted Mercruiser. The block was cracked after I believe to be a improper winterization. I didn't know it was cracked and ran the engine for about 30 min. to an hour when it started to stumble pretty bad, so I backed off the throttle to idle and the engine died. Opened up the engine compartment and there was milky, frothy oil everywhere.
Now I have take the drive off and have the engine all unbolted ready to be lifted out but don't want to until I get a new engine bought. My question is what all do you think I need to replace/should replace. My engine only had about 250 hours on it so I was looking at getting a shortblock engine from somewhere (looking at rapido, looked like they had some good reviews on here but still open to suggestions) and then putting a lot of parts from my old engine on it.
I also was thinking that I probably need to replace the heads, is this correct to assume. Calling Rapido today they also mentioned that I should probably replace waterpump, themostat, starter, distributor and such since I am in there. What are your thoughts on this these or do you think my parts since they are low hours will work.
Also when I talked to Rapido today they really pushed replacing the exhaust manifold and risers and all of that. Do you think this is needed or can I get away with just gaskets?
I am doing this on somewhat of a short budget but want to do it right at the same time so I am just trying to get a idea of what I really need, should probably get and what isn't completely needed.
Thanks in advance.
Thanks in advance.
