what type of gas generator would i need for
lime4x4
A 86 27 foot searay weekender? Would like to install a gas powered generator.
arks
Re: what type of gas generator would i need for
It depends on what you intend to run with the generator. We need more info to give you an accurate answer.
lime4x4
sorry..frig,electric stove,microwave,hotwater heater and also to be able to recharge the batts,Currently there is a trickle charger installed for the batteries but that only works when connected to shore power
arks
OK. The first thing you might consider is replacing the water heater with a heat exchanger style. They've got an additional pair of fittings for engine coolant to circulate thru and keep the water hot without using any electricity. I have a 10 gallon unit and the water will stay hot all afternoon after shutting down the engine.
Now, the genny- if you don't run everything at the same time, you could get by with a portable like the Honda eu2000i. It's NOT designed for marine use and must always be setup so carbon monoxide can't collect in the boat. They're about $900, which is less than half of a small installed marine generator.
OTOH, if you spring for an installed marine genny, your AC power is just a pushbutton away. I think a 3kW model would do the job, but a bigger one would allow an A/C unit to be added in the future. Either way, your boat's value will go up considerably with a proper marine genny installed.
I'm currently in the process of installing a new 5kW Kohler "low-E" model in my boat. It's a big job that requires a lot of planning (and money!) but so far so good.
lime4x4
Well it already has the heat exchanger for the hotwater tank so i'm good there.
I like the idea of installing the jenny in the beilge area and just flicking a switch.I'll have to look into that some more for a nice winter project.
Thanks for the info
Reel Poor
If your going to do a permenent install don't consider anything smaller than 5kw.
