I have a 2000 Chris-Craft with a sunpad engine cover, and the Cradle & Pin hinge set-up had the pin portion shear off. I asked Chris-Craft, and they said they could order a set for arond $300. I asked my brother, who works at an aircraft repair shop, and he said he can have it welded, and probably stronger than before. He has asked me the following regarding the stainless steel used to manufacture the hinge. I have no idea, and was wondering if anyone who has done welding on some marine grade stainless, if they could shed some light on the materials used? Please see below, and as always, that you to everyone for the knowledge.
Find out what the parent material of the hinges is. Is it 17-4 stainless, 15-5 stainless. Also, maybe they can tell you what weld wire (filler wire) they used to weld the pieces together at original manufacture. Possibly an AMS spec. Weld wire used would be very helpful, but parent material as well would be even better. I may be able to find out a better filler wire.
