what will this prop fit
trevin11
LaserII 48 16992 a40 its diameter 13 1/2 its on my 150 HP mercury not sure if that's big enough there is a gap between my prop and gear case about a half inch just got the boat and top speed at 6000 rpm is 45 that's off my GPS and I'm thinking it should be going at least 55
tpenfield
Re: what will this prop fit
Sounds like the prop is for the 4-1/4" gearcase and you have the 4-3/4" gearcase. . .
Ayuh,.... Agreed,... That prop is for a mid-sized gear case motor,....
Yer motor uses the Large gear case...
