Re: What year is my 25h.p. johnson
hey gluck. i havnt looked up your model #, but it should be a 1974 (thats what the 74 means, no?) my 25hp johnson 1972 has the "72" in the model #. anyways, how does the lower unit oil look? nice and clean or cloudy/rusty/non-existent. could be several things. broken shifter lever. broken shifter rod. seized lower unit. give us some more info on the exact problem. try removing the shifter rod disconnect door and see if everything looks good. if the connecter moves with your shifter lever then the problem is probably in the lower unit itself. not a big job. let us know.<br />LM
