What year is my 88SPL? Not like this usually is asked.
lmuss53
I bought this 88SPL from a neighbor to clean up and resell. The label that usually give the information I asked for is gone. Can anyone look at the paint and underhood layout and give me a good idea of the year. FWIW it has factory tilt/trim.
hardwater fisherman
No Title
1987 and 1988 had the same decals. This is a photo of a 1988 model and it looks like yours.
hardwater fisherman
No Title
This is the decals for 1987 and 1988. With a quick search I think 1987 was the first year for the 88spl.
Fed
I have a stock standard 1988 90 HP Evinrude and it doesn't have the schrader valve on the primer valve which would make me think yours is later than 1988 unless it's been upgraded.
I don't think tilt& trim came with unregulated (see stand alone rectifier) motors.
I'm thinking the powerhead & cowl may have been replaced with a poverty pack later model.
lmuss53
No Title
This is an unregulated rectifier model, the primer got me thinking, but that started with VRO in 84, 85 didn't it? The carbs have socket head cap screws (Allen bolts) not hex head bolts. It also looks like the ID plate was a decal, not the old stamped aluminum plate. I'm thinking early 90's? It has the carbs with the plates on top, and the throttle mechanism is different from an 86 VRO model 90 I once owned.
emdsapmgr
The 88 SPL models were actually a 90, stripped of expensive parts to hold the cost down. An OMC marketing gimmick to reduce the sale price vs Mercury. Base price did not include: a combination regulator/rectifier (rectifier only), No VRO pump, no power trim. At the time of dealer purchase, the new owner had to option of adding components. As a result, many of these 88 specials did have power trim. Added at point of sale. Other than these items, it is a basic 90 hp Johnson.
lmuss53
Carbs built in 09 of 1989. Pic too big from phone camera looks bad on tablet camera.
Fed
BRP website shows schrader valve first introduced in 1991. Not there on a 1990 or earlier models.
lmuss53
OK Fed, thank you, it gets newer and newer. ;) I'm gonna look the 91 parts blow up over, I think it needs a roller in the throttle mechanism.
hardwater fisherman
No Title
I was only going by the decals. If the decals were 1990-1991 then the 88 under the johnson logo should be red.
AEROCOOK
The thumb wheel type timer base adjustment suggests newer than 1988 unless it's been changed. The timer base adjustment on my My 1988 110 is the old style block with 3 holes.
As for the schrader valve, my 1990 88 SPL doesn't have it so 1991 or newer is looking likely.
Schreader valve was retro fitted on many motors as an accessory to add fogging oil.
lmuss53
I don't think the retrofit could have happened here, the carbs were never fitted with chokes.
I can't find a welch plug with the model number either, although I didn't search real hard, and the cover is back on now, packaged to travel.
I looked on a bunch of websites and I can't find that throttle assembly in the parts diagrams??? I made a roller out of some vinyl tubing I had here.
I called it a 1990 on ebay, might change that.
Thanks for the responses fellas.
