SparkieBoat
Thread starter- Joined
- Aug 17, 2009
- 3,643
I read the secret files section on this and can not seem to find 1999 and up V-4 90 degree motor. I need a used gear case and needed to know what year models will work. it is a 25' shaft if it makes any diff... here is the chart from secret files.
Horsepower--------------------------------------Years that interchange
40/48/50/55/60..... (small diameter housing)..................1976-1988
40/48/50................................................ .................1989-1992
40/48/50................................................ .................1993-2005
70/75............................(20 inch shaft)......................1978-late 1981
60/65/70/75................................................ .............1982-1988
50/60/70................................................ ..................1989-2001
85-140.............(crossflow 13 spline prop shaft).............1978-1991
88-140.............(crossflow 13 spline prop shaft)..............1992-1998
120-140 Looper V-4... (15 spline prop shaft)...................1985-1991
75-115 60 degree........(bat wing unit 13 spline)...............1995-2006
150-235 & 2.6.................(crossflow V-6)......................1979-1991
185-225.........................(Looper V-6).........................1986-1991
185-225....................(Looper V-6 & Ficht)....................1991-2005
150-250.......................( Magnum Series).....................2002-2007
150-250........................(Lighting Series)......................1997-2001
