Re: What Yr. Am I?
recommend some gas and a little thumb pressure to clean the bowl. Use carb cleaner only sparingly, if at all (helps in cleaning a dirty jet). Once the carb is clean, see if you can fire it up and run some clean gas/oil through the system.<br /><br />Good luck -- sounds like a nice little engine.
