Whats a 'Looper' and a few other questions
npd4432
Re: Whats a 'Looper' and a few other questions
Pretty long but here is a good read on the history of the v4 looper/crossflow
The history of the Johnson/Evinrude V4 product line is very complex but can be greatly simplified
if looked at from a point of engine design changes and the year of these changes. They can be broken down into four distinct generations.
1958-1968 V4 Outboards
Prior to 1958 all Johnson/Evinrude engines were either a one or two-cylinder. In 1958 the V4 was introduced.
The first V4 was rated at 50 horsepower and the basic engine design was manufactured from 1958-1968 reaching a pinnacle of 85 horsepower in 1968. This engine is most commonly identified by its single 2-barrel downdraft carburetor.
In 1964 a second V4, with minor changes, was introduced. It was manufactured from 1964-1968. This engine utilized a single inline four barrel side draft carburetor to make 90 horsepower. For
the 1966 model year this was the first Johnson/Evinrude outboard to produce 100 horsepower.
Externally the 1958-1959 V4 can be identified by an square(ish) engine cover with spark plug access doors. The 1960-1968 V4 can be identified by a more rounded engine cover without doors.
All 1958-1968 models have exhaust gases that exit through the cavitation plate (through-the-prop exhaust wasn't available on the V4 engines until 1969).
Other notable design changes for 1958-1968 V4 engines:
-1961 First year for battery ignition (magnetos would continue on some models until 1967).
-1967 First year for breakerless ignition, 100 hp only.
-1968 First year for mounting the distributor under the flywheel (no more belt driven distributors).
1969-1984 V4 Crossflow Outboards
In 1969 the Johnson/Evinrude V4 engines were completely redesigned from top to bottom. Since 1985 (when the V4 loopcharged engines were introduced) these outboards have been commonly called the "crossflow" V4 engines. Although manufactured from 1969-1997 they received no significant design changes after 1984.
The 1969 V4 crossflow engines were sold in two sizes, 85 and 115 horsepower. The pinnacle would be the 140 horsepower manufactured from 1977-1984.
There are three very distinguishing characteristics that separate them from the 1958-1968 engines:
The first and most obvious is the modern, sharp edged, triangular engine cover that emphasizes the low profile of the 90 degree crossflow V4 engine (a contrast to Mercury's tall inline six cylinder).
The second is the new one piece gearcase with through-the-prop exhaust and rubber hub propellor (no more shear pins for the V4).
The third is the two side-draft 2-barrel carburetors. None of the crossflow V4 engines were ever equipped with fuel injection, only carburetors.
Other notable design changes for 1969-1984 V4 engines:
-1969 First year for the V4 with a electric/hydraulic shift gearcase with one mechanical cable running from the control box to the outboard (the throttle cable).
-1973 First year for the V4 with a mechanical/hydraulic shift gearcase with two mechanical cables running from the control box to the outboard (throttle and shift cables).
-1973 First year for distributor-less ignition (one coil per cylinder with timer base and sensor).
-1978 First year for the V4 with a full mechanical shift gearcase.
-1984 First year a V4 used the large V6 gearcase and large diameter prop.
1985-1994 90 degree V4 Loopcharged Outboards
From 1985-1994 these outboards were commonly called the V4 "loopcharged" engines. When
the compact "60 degree" V4 engine was introduced in 1995 the 1985-1994 engines were called
the "90 degree" V4 loopcharged engines. Although manufactured from 1985-1998 they received
no significant design changes after 1995. The 90 degree V4 loopcharged engines have come in different horsepower ratings between the 120 hp (smallest) and 140 hp (largest).
The introduction of the loopcharged V4 in 1985 brought the Johnson/Evinrude "V" engines into the modern age of two-stroke engine technology.
A crossflow two-stroke has one transfer port delivering the air/fuel mixture to the combustion chamber from the crankcase. A large and heavy deflector is designed into the top of the piston to direct the air/fuel mixture to the spark plug and to keep it from being discharged directly out of the exhaust port.
A loopcharged two-stroke has three transfer ports, one in the back (similar to a crossflow), and one on each side of the cylinder. The three transfer ports direct the air/fuel mixture to the spark plug and away from the exhaust port without the need for a piston deflector. This is accomplished by casting the cylinders with very precise contours in the transfer ports. The addition of two extra transfer ports in a loopcharged engine also feeds larger quantities of the air/fuel mixture to the combustion chamber. This provides a dramatic increase in power over a crossflow engine.
The main drawback to a loopcharged engine is the cylinder size. With two extra transfer ports cast into the sides of each of the cylinders, each cylinder is much wider. The loopcharged V4 engine is much taller than the crossflow V4 engine. The bore spacing on a loopcharged engine is 4.750 inches. The crossflow engine is 4.125 inches. For identification purposes, this is also the distance between the spark plugs.
Some other identification methods are:
-Removable transfer port covers on the crossflow engines versus non-removable transfer port covers on the loopcharged engines.
-The exhaust port cover is removable on the crossflow and is cast into the block on the loopcharged.
-The loopcharged V4 engines have four individual one barrel carburetors.
-All 90 degree V4 loopcharged engines come with the large V6 type "O" gearcase and large diameter prop.
1995-Present 60 degree V4 Outboards
In 1995 the V4 outboards were completely redesigned. Between 1958 and 1994 all V4 Johnson/Evinrude outboards were manufactured with a 90 degree angle between the two banks of cylinders. Taking advantage of modern aluminum casting techniques, Johnson/Evinrude was able to design and manufacture a very compact 60 degree V4 engine for the 1995 and newer models.
The 60 degree V4 has very few parts that will interchange with the 90 degree V4. The biggest difference between the 90 degree and the 60 degree is the location of the carburetors/throttle bodies. While a traditional outboard engine will have them mounted in front of the engine, over the crankcase, the 60 degree V4 has them mounted on the side of the engine, over the transfer ports.
A new small mechanical shift gearcase was introduced on the standard length engines. The long shaft engines use the large mechanical shift gearcase.
Four Generations of Johnson/Evinrude V4 Outboards
(Always use appropriate manual when servicing engines)
First Generation:
When a marine technician encounters a 1958-1968 V4 outboard, common sense and a basic understanding of a points style (magneto or battery) ignition will get them through the ignition system. Mechanical aptitude will get a technician through the relatively simple fuel system. The gearcases on these models are very easy to rebuild (as long as you remember to feed the wires through before pulling the magnets out of the electric shift gear case).
Second Generation:
Perhaps the most common outboard ever manufactured is the 1969-1997 V4 crossflow Johnson/Evinrude engine. In production for 29 years these are as basic as an outboard gets. Having the correct service manuals and a basic understanding of breakerless ignitions and fuel systems will get a technician through just about any problem. One special tool is needed to rebuild the gearcase: a pinion height measuring tool. This tool can be used on all 1969 and newer V4 and V6 outboard gearcases and 1978-newer OMC and Cobra Sterndrive gearcases. Definitely a tool to invest in!
Third Generation:
The 1985-1998 Loopcharged 90 degree V4 Johnson/Evinrude outboards are also very common and are serviced almost as easily as the earlier V4 crossflow engines. As with the crossflow engines, a service manual and a basic knowledge of breakerless ignitions and fuel systems will get a technician through most tasks. Rebuilding the mechanical shift gearcase is relatively simple with a pinion height measuring tool.
Fourth Generation:
Service on the 1995-newer 60 degree V4 is a little more complicated. Having the correct service manual and some specific Johnson/Evinrude tools is almost a requirement. These engines
came with carburetors or DFI (Direct Fuel Injection) and attending a factory service school is
almost a necessity for diagnosing the ignition system or fuel system. The gearcase is a traditional mechanical shift design and rebuilding it is relatively simple with a pinion height measuring tool.
ondarvr
I thought I'd post the model number for my CF.
E90TSLECM
walleyehed
'There was a lot of overlap with the OMC V4s & V6s with crossflows and loopers being sold during the same model year from the mid 1980s into the 1990s. The last OMC crossflow V4s were the venerable 88SPL and 112SPL models in 1996.'
1998 was the last year of the V4 crossflows...they had the spls+ std 90-115.
I owned the '98 115 .
from '94 thru '98 you could get either version.
