What's a poppet valve?
The Marine Doctor
Re: What's a poppet valve?
Poppet valve is a spring loaded plunger (for lack of a better word) Its use is to slow down the water that travels from the waterpump, by doing this the water is able to warm up a bit before it gets to the hottest cyl. <br /><br />TMD
greenoats
Would no poppet valve cause #2 and #3 cyl to not operate?
greenoats
It's a 3-cyl 65 horse.<br />new powerhead but forgot the poppet when assembling, got one on order.
CU2NITE
No the poppit helps regulate water temp. and water flow.<br />CU
Merc90HPnewbie
Where can I locate this? For example on a 90 HP Mercury straight 6? :) What do I have to do to pull it and inspect it?<br /><br />Thanks!
CU2NITE
I'm not sure on this motor, mine is an 85 150 merc and it's located on the base of the powerhead on the drivers side. If you don't have a manual get one. Good luck.<br />CU
Merc90HPnewbie
Checked the powerhead and manual. The manual mentions poppet valves and thermostats but doesnt say where to find them. Looked on the engine and didn't see anything... :(
CARLOS
MINE IS A V6 ENGINE AND HAS 2 POPPET VALVES , ONE ON THE BASE OF EACH ENGINE HEAD. IT CONTAINS A SPRING & VALVE WHICH CONTROL THE WATER FLOW...IF IT IS WROKEN, MAYBE THE ENGINE OVERHEAT...<br /><br />REGARDS<br /><br />CARLOS SCHEMEL<br /><br />VENEZUELA
