freeisforme
Thread starter- Joined
- Mar 23, 2009
- 184
About a year ago I picked up a great little 14' 4" MFG fiberglass V hull with intentions of hanging a 50hp motor on it, maybe a fresh transom job, and two new seats to use for fishing the river around here. It's been on the back burner waiting for me to get around to it. The hull is rock solid, it's got no damage, no patches, and a rock solid deck.
Well, after riding in the same model boat this weekend, I now have my doubts whether or not this boat will work at all for me. At 6' 3" tall and 360lbs, and being the lighter of most of my fishing buddies, I don't think this boat is safe with just the weight of two guys in it?
A buddy and I took his out this past week, he's got a 40hp motor on his, and two pedestal seats mounted on an aluminum reinforcement plate. The first thing I noticed was that the seat, even though the pedestal was only about 6" long, was way too high, I sat with my head fully above the windshield. Second, there was no place to put my knees, they wouldn't fit under the dash, and the seats were too close together to sit sideways. (It would have been fine if there was one seat dead center, that way it could be positioned so I had some arm room and legroom. But putting two seats in line would kill almost all the free deck space too. The boat was stable at rest, (it didn't feel like it would flip or dump us even if we both moved to the one side), but it rode low at the stern, and the motor's cover and pan would dip into the water if both of us were at the back of the boat.
Needless to say I don't think the boat is capable of safely carrying 700+lbs of passengers, tackle, and fuel safely. It would make a great one man boat but that's not what I need.
My question is, what is a hull like this worth? I don't want to just give it away, its in good shape and has great potential but just not for big people to use. A couple of guys maybe 200lbs or so would be fine.
The hull is not waterlogged, it's a bit faded and dusty now but buffs right up, (I had it all buffed up and looking nearly new when I first got it, but it's sat now for a year). I'd like to find it a home and keep the new trailer I bought for it and go find a 16' boat, which I figure is about the limit of my tow vehicle.
One thing that got me is that I've been using a 14' aluminum boat for years, it holds three guys, all over 300lbs well, it moves and planes out with a 20hp motor and is very stable with good freeboard. What's different about the wider and even slightly longer MFG hull?
The MFG is light, I can lift either end myself, with little effort, I'd guess it's no more than maybe 450 or 500 lbs total. The stern is lighter than the bow end. The deck is solid glass, and from what I'm told it's got no wood in the lower hull either, and a look into the drain hole in the back with a bore scope camera shows no foam flotation either. The flotation seems to be a combination of the trapped airspace below the deck and foam in the gunwales and under the bow plate.
At this point I'm leaning towards maybe finding a small trihull to make into a fishing boat, something light, and one that will handle well with a 50hp motor with thought that it'll have more surface area and handle more weight for it's size.
