What's my Boat Made Out Of???
Dry Diver
Hello,
I have a 1984 Achilles inflatable. I am unsure of which material it is made out of. Hypalon or PVC. Is there any way to tell. I am interested because I think that I might have some patch work to do and wonder if the method of preparing them is any different.
Thank you in advance for all the help.
Huron Angler
Re: What's my Boat Made Out Of???
This is from the 1984 Achilles inflatable boat brochure:
[Achilles starts with a heavy duty nylon core material produced to their own exact specifications. This tough basic fabric is then strengthened further with two durable man-made elastomers, Hypalon and Neoprene. Instead of using a vinyl-based coating on the exterior of their boats as some other manufacturers do, Achilles uses Dupont Hypalon. Hypalon is a superior additive for resisting damage from abrasions, punctures, oil, gasoline or the weathering effects of the sun, ozone and warm salt water. And Achilles uses an industry high 80% Hypalon compound developed through years of experience and testing.]
This is the link where the brochure can be downloaded-
http://www.achillesinflatables.com/downloads/
This is the actual brochure-
http://www.achillesinflatables.com/pdf/files/1984achilles_catalog.pdf
I hope this helps- I know I just learned a decent amount about the Achilles- they seem like pretty solid little boats.
Where do you dive? I'm in Michigan and we have some land within a new Federal Marine Sanctuary designed to protect shipwrecks. All I need to do is finish my open water certification and buy a few more pieces of gear and I'll be diving:D
Drowned Rat
Achilles uses Hypalon as stated.
You can find detailed repair procedures here >> www.nrsweb.com
As well as all the materials you'll need to do the job.
deejaycee_2000
You can patch it with hypalon or PVC material as it needs to be glued anyway ....
