what's one more boat ? - 1979 Sunfish
edgepa
I couldn't resist. Plus this one looks like it is in pretty good shape, but I haven't gone over it in close detail. My first job is to make sure that the trailer is road-ready as I will be pulling it 1,800 miles in August. I will repack the hubs and check the leaf springs for cracks. Tires are new so they should be ok.
sphelps
I’ve never rode in a sail boat . That’s on the bucket list . I’m just afraid I might enjoy it and end up with a yard full of em ..
:facepalm:
edgepa
Well it’s been 20 years since I have sailed so I am hoping it goes well. But so far it is worth it as my son asked if he can use it this weekend locally. :clap2:
edgepa
I have decided to sand off the surface rust and give it some rattle can love to the trailer. The plan is to:
  • sand with an orbital and 150 grit
  • wipe down with acetone
  • 2 coats primer
  • 2 coats paint
If there is an error in my process, please let me know!
edgepa
  • 2 coats primer
  • 2 coats paint
Well the last post was, well, awhile ago. Seems like a lot was going on. Anyway, I wonder who laughed when I said “surface rust”? I now know that’s not a thing. I had to sand the heck out of that thing. But there was a pretty good outcome for the trailer.
So the plan was to take the boat up to the cabin in 2019, but despite all my planning we ended up with a Beverly Hillbillies trailer/truck set up. So it was pushed to summer 2020. Then a global thing happened.
So fall 2021, the boat was hauled 1800 miles to the cabin and sailed finally on the lake. And subsequently stored under the cabin. And yet the trailer was brought empty back home.
Although nothing was denied, I may have had a secret plan. What fun is one sailboat? Sure, a leisurely sail is nice. But I know my family. A little cut-throat competition is more our style. One boat good; two boats better.
Two weeks ago, I picked up #2 for $40… and plenty of problems. I will need some help with a Frankenstein fiberglass re-do. Please see pictures…
Also mods, let me know if this should be a new thread.
tpenfield
I introduced my family to boating with a Sunfish. I still have it to this day, but don't get it out often (too many boats). If I can grab a trailer for mine, I'd probably use it more often.
elsaylor
+1 i learned to sail on about that same boat right there good stuff maynard
edgepa
Cut in two inspection port openings. I was able wet vac about a gallon of water out of the stern. Foam was in good shape, but nonetheless will run a fan for a month or so.
Also this will provide access to put in a backing plate for the new style rudder. So much work to do back there.
76SeaRay
Keep in mind that all sailboats can easily be capsized and especially the smaller ones. When they do capsize, they rely heavily upon the floatation foam to keep it afloat and to right it once you get yourself out of the water at the centerboard. Waterlogged foam is not good news on any boat but particularly important not to have it on these small sailboats. If you "turtle it" with waterlogged foam, you won't right it without power boat assistance, that is if it doesn't sink on you.
edgepa
Hey 76searay,
Totally agree. According to some Sunfish user groups waterlogged foam can be dried out with the fans. The goal is to get back to 139 lbs. So, let’s see what happens. All the foam I can touch so far seems good.
The fiberglass work at the rudder concerns me the most. It is so messy. I think it is the source of the leak.
I have yet to capsize in a sunfish, but that’s because I haven’t pushed it yet. Maybe this summer I will get more aggressive.
76SeaRay
Handy tip from an old sailor, if you capsize and can't get it upright quickly, swim around and tie a life jacket to the top of the mast. That helps prevent it from going turtle. Enjoy the swim when you capsize, unless you are quick enough to climb up over the gunwale and onto the centerboard to right it. It is possible to capsize and right without getting your feet wet, nimble and quick and on a smaller boat.
edgepa
Yeah, I am not that quick at 57 despite what I pretend to be.
I have seen people put a flotation on the mast to prevent turtling. I assume the resistance on the sail gives you some time… even at 57.
76SeaRay
Yup the sail gives you some time to get it done. Some people have put floatation foam inside their aluminum mast. I do miss sailing but got too old to manage stepping the mast on my 24ft American. I have sailed 12 foot Kites, International 14's, 16 foot C-Larks, 18 foot Lightnings, 16 foot Hobie Cats, 24 foot American, 36 foot Cal, Morgan 41, a 70 foot Square Rigger and an 80 foot Square Rigger. All were a blast but the best of all was getting to sail the 1987 America's Cup winner Stars and Stripes after she was retired. Now its back to power for the "easy life", yeah right with the price of gas these days. I may not get all the restoration done this year but really hope to splash the Sea Ray late this summer.
edgepa
I am ready to remove this mess of fiberglass. I assume the only way to do it is by aggressively sanding. Any tips?
todhunter
Canoeist
Angle grinder and 40 grit flap discs....and a respirator, tyvek suit, and goggles. Prepare to get itchy!
edgepa
I took the Angle grinder with 40 grit flap wheel to the ugly fiberglass on transom. It really ripped the material off quick. Dangerously quick! Looks like I got into the original gel coat. I think I will use an orbital with 80 grit to finish.
Based on the photos, how much more do I need to remove? My goal is have flat surface that matches the white hull. Can I just add faring compound at this point? And how about the “cavities”? Special treatment for those?
