What's the diff?
just plain ole Bill
Been looking at tilt motor/pump pkgs. Some are 2 wire some 3 wire. A picture of a 3 wire showed two of the wires to a common lug. Was the picture wrong or is there a real difference?
QuadManiac
Re: What's the diff?
2 wire simply swaps power and ground wires to reverse direction (hooks up power to wire A and ground to wire B for up, Power to wire B and ground to wire A for down). 3 wire has 2 different windings with a common ground, you apply power to one winding for up, apply it to the other winding for down, ground always stays connected to the same place. If your boat/motor is already wired for one, you would have to modify/adapt the wiring to support the other. It's not terribly difficult.
Others here can tell you about any mechanical or performance differences, if they exist.
just plain ole Bill
Was hoping it was that simple. Took mine apart to fix a leak now I have 40 parts in a baggie and think there's supposed to be 42 parts. Found a good deal on a 3 wire and mine is (was) a two wire. That's what I needed to know, THANKS!
