whats the difference between an ocean runner and a fast strike?
bob johnson
Johnson made two 115 hp 60 degree V4 motors in several years in the late 90's
one was called the OCEAN RUNNER
and the other was called FASTRIKE
one had a 500 rpm higher WOT and developed its HP at 500 more RPM as well
I looked up many parts and they are all the same number between the 2 motors,
heads, crank, pistons, block
the rev limiter was the same, the timing was the same( i have the manual which covers both)
the gear ratios are the same...
what is different that creates the HP at a higher rpm on the Fastrike ???
evinrude had the same situation , OCEAN PRO and INTRUDER
just curious
hope someone knows
bob
jonesg
Re: whats the difference between an ocean runner and a fast strike?
Higher rpm models are usually a carb and cyl head difference.
