whats the difference between these 2 part numbers?
Tailguner
mercruiser part # 807166a1 and mercruiser part # 807166a3 is there a difference?
i have a 2000 merc 454 serial #oL621407 mpi gen VI L-29
stonyloam
Don S
Re: whats the difference between these 2 part numbers?
I believe A1 fits inside of the pipe, and A3 fits on top and replaces an older style shutter.
Actually, the A3 shutters are the new style, the A1 is the old style. If ordering from Mercruiser, the A3 will be sent if you were to order the A1.
Fun Times
While normally this is known to be true, Actually in this case it appears not to be true at this time.
Part number 807166A1 shows no Item Supersession Chain from mercruiser.
But part number 807166A3 Shows these part numbers in the Item Supersession Chain:
Row Class Part Number SS Level Disp Description
1 807166A3 00 ACT SHUTTER ASY(PAIR)
2 14348 01 SS WATER SHUTTER
3 14348A1 01 SS SHUTTER ASY-WATER
4 14348A2 01 SS SHUTTER KIT-WATER
Tailguners engine should require him to use part number 807166A1.;):)
http://www.mercruiserparts.com/Show...5.png&inbr=2705&bnbr=270&bdesc=EXHAUST+SYSTEM
Mercruiser also has a stand alone part number of 807166A2, But it has no good picture of what this style shutter looks like that I can find, But it looks like achris remembered the differents.
http://forums.iboats.com/showthread.php?t=426899
Tailguner
i was hoping i could use the a3 in my engine.....
Tailguner
don s. will the 807166a3 work for my engine?
