Re: whats the easiest way to empty gas tank?
There's two ways to get that fuel, now that you have the carb off. You can hook the fuel line that went to the carb to the inlet side of an electric pump, and pump the fuel into a bunch of gas cans, or you can hook a long piece of hose up to the same line and siphon the fuel out. If you're going to siphon it, the boat should be out of the water. Otherwise, to get the output end of the siphon lower than the input you'll be underwater. And that's not very comfortable this time of year.
